rate-limiter-flexible
7.1.1 • Public • Published
npm version npm node version deno version
Logo
node-rate-limiter-flexible
rate-limiter-flexible counts and limits the number of actions by key and protects from DDoS and brute force attacks at any scale.
It works with Valkey, Redis, Prisma, DynamoDB, process Memory, Cluster or PM2, Memcached, MongoDB, MySQL, SQLite, and PostgreSQL.
Memory limiter also works in the browser.
Atomic increments. All operations in memory or distributed environment use atomic increments against race conditions.
Fast. Average request takes 0.7ms in Cluster and 2.5ms in Distributed application. See benchmarks.
Flexible. Combine limiters, block key for some duration, delay actions, manage failover with insurance options, configure smart key blocking in memory and many others.
Ready for growth. It provides a unified API for all limiters. Whenever your application grows, it is ready. Prepare your limiters in minutes.
Friendly. No matter which node package you prefer: valkey-glide or iovalkey, redis or ioredis, sequelize/typeorm or knex, memcached, native driver or mongoose. It works with all of them.
Safe for using with valkey cluster. valkey-glide implementation, RateLimiterValkeyGlide, is being tested to ensure compatibility and high performance.
In-memory blocks. Avoid extra requests to store with inMemoryBlockOnConsumed.
Allow traffic bursts with BurstyRateLimiter.
Deno compatible See this example
It uses a fixed window, as it is much faster than a rolling window. See comparative benchmarks with other libraries here
Installation
npm i --save rate-limiter-flexible
yarn add rate-limiter-flexible
Import
// CommonJS
const { RateLimiterMemory } = require("rate-limiter-flexible");
// or
// ECMAScript
import { RateLimiterMemory } from "rate-limiter-flexible";
// or
import RateLimiterMemory from "rate-limiter-flexible/lib/RateLimiterMemory.js";
Basic Example
Points can be consumed by IP address, user ID, authorisation token, API route or any other string.
const opts = {
  points: 6, // 6 points
  duration: 1, // Per second
const rateLimiter = new RateLimiterMemory(opts);
rateLimiter.consume(remoteAddress, 2) // consume 2 points
    .then((rateLimiterRes) => {
      // 2 points consumed
    .catch((rateLimiterRes) => {
      // Not enough points to consume
RateLimiterRes object
The Promise's resolve and reject callbacks both return an instance of the RateLimiterRes class if there is no error. Object attributes:
RateLimiterRes = {
    msBeforeNext: 250, // Number of milliseconds before next action can be done
    remainingPoints: 0, // Number of remaining points in current duration
    consumedPoints: 5, // Number of consumed points in current duration
    isFirstInDuration: false, // action is first in current duration
You may want to set HTTP headers for the response:
const headers = {
  "Retry-After": rateLimiterRes.msBeforeNext / 1000,
  "X-RateLimit-Limit": opts.points,
  "X-RateLimit-Remaining": rateLimiterRes.remainingPoints,
  "X-RateLimit-Reset": Math.ceil((Date.now() + rateLimiterRes.msBeforeNext) / 1000)
Advantages:
Full documentation is on Wiki
Middlewares, plugins and other packages
Some copy/paste examples on Wiki:
Migration from other packages
  • express-brute Bonus: race conditions fixed, prod deps removed
  • limiter Bonus: multi-server support, respects queue order, native promises
Docs and Examples
Changelog
See releases for detailed changelog.
Basic Options
  • points
    Default: 4
    Maximum number of points that can be consumed over duration
  • duration
    Default: 1
    Number of seconds before consumed points are reset.
    Points are never reset if duration is set to 0.
  • storeClient
    Required for store limiters
    Must be @valkey/valkey-glide, iovalkey, redis, ioredis, memcached, mongodb, pg, mysql2, mysql or any other related pool or connection.
Other options on Wiki:
Smooth out traffic peaks:
Specific:
API
Read detailed description on Wiki.
Contributions
Appreciated, feel free!
Make sure you've launched npm run eslint before creating PR, all errors have to be fixed.
You can try to run npm run eslint-fix to fix some issues.
Any new limiter with storage must be extended from RateLimiterStoreAbstract. It has to implement 4 methods:
  • _getRateLimiterRes parses raw data from store to RateLimiterRes object.
  • _upsert may be atomic or non-atomic upsert (increment). It inserts or updates the value by key and returns raw data. If it doesn't make an atomic upsert (increment), the class should be suffixed with NonAtomic, e.g. RateLimiterRedisNonAtomic.
    It must support forceExpire mode to overwrite key expiration time.
  • _get returns raw data by key or null if there is no key.
  • _delete deletes all key-related data and returns true on deleted, false if key is not found.
All other methods depends on the store. See RateLimiterRedis or RateLimiterPostgres for examples.
Note: all changes should be covered by tests.
Package Sidebar
Install
npm i rate-limiter-flexible
Weekly Downloads
1,001,463
Version
7.1.1
ISC
Unpacked Size
176 kB
Total Files
37
Last publish
Collaborators
  • animir
